2003 700 venture
Gitterdun1985
Lincoln, New Brunswick
Im working on my neighbours sled for him. its a 2003 700 venture. he told me it needed some suspension work, needless to say its more than suspension work. The speedo bearing let go and they drove it for god knows how long which ruined the bottom bearing on the chaincase also. I told him i could fix it no problem. for the gearing on the sled will any gears work from 97-03 or is it just certain years. any input would be greatly appreaciated.
13 wide, 15 wide, HYVO, non-HYVO, you have to get the matching gears & chain. Would have to look at what you have now.
it should have hyvo chain and gears in it. You can swap everything out with another pro action chassis chaincase and any year chain and gears if you use them as a set.
HYVO or non
I'm sure Don is probably right.....it's probably HYVO. But if you find out it is not I have a set of non-hyvo reverse gears I'd see ya cheap.
Madmatt
