Pulled my carbs because I was getting a bog off the line. Since I had someone run my carbs in the fall, I figured I should go ahead and do it and make sure they're right.
Well I'd tracked the bog down to probably being the fuel screws. So I screw them all in from where they were positioned and none were the same....
So I pulled the jets, they were all clean.
Pulled the fuel screws and the opposite cylinder of the pto side was white and cruddy so I cleaned it off. Also sprayed some cleaner in the fuel screw holes and watched the cleaner come out so they're clean.
Put the screws back in and backed them out 2 and 1/8 turns.
Got it all back together and got it started and it's hitting on two cylinders I think. It's also now getting a weird hang up and not wanting to go back down to 1600 rpm all the time.
I'm beginning to wonder if it's jetted right, but mind you I'm doing this work down in Denver and ride around 9-11k feet, but it shouldn't run this choppy all of a sudden I wouldn't think.
I'll keep some more videos coming and feel free to suggest anything for a video that could help with some advice.
It's my first time messing with carbs and I'm scared I'm going to have a melt down.
Oh also I pulled the plugs and pto plug was pretty bone dry while the other two had some oil on them so I opened the oil cable up a little as I'm still dialing in my oil cable since it's aftermarket.
Here's where my videos are
I've got a couple of the choppy sound and some of the throttle hangup. I gotta run into work or I would mess around more.
http://www.youtube.com/user/Milo3o3/feed?feature=context
