devinzz1
staggs65
devinzz1
staggs65 said:
already looked at it..... wasnt very helpfull. dont know whats going on
Is that the top of your steering stem
devinzz1
y201srx said:Is that the top of your steering stem
yes. the very top
Ur taking a big chance welding that back on I would have someone tig weld it.I think best way to fix is put a piece of smaller diameter pipe down threw top and inside the stem bevel the edges leave a 1/4 inch gap so you can get good penitration to all three pieces that's something you don't want breaking off at 100 mph just my opinion I'm a welder by trade tig would make the strongest weld.
HndaTch627
devinzz1 said:already looked at it..... wasnt very helpfull. dont know whats going on
He put a pipe down the center of it, and welded it at the bottom through some predrilled holes and then did the same at the top as well as welding the top plate back to it.
devinzz1
yes. the very top
staggs65
exactly, thought it was described pretty plainly if you read it.HndaTch627 said:He put a pipe down the center of it, and welded it at the bottom through some predrilled holes and then did the same at the top as well as welding the top plate back to it.
devinzz1
staggs65 said:exactly, thought it was described pretty plainly if you read it.
well bye i did but looking at the pic it looks like a tube was put on the outside
I added gussets on the bottom of the plate on mine in addition to the reinforced post.
HndaTch627
I think the OP would have understood what he did better if he saw a picture of the pipe inserted into the tube before welding the top plate back on. Either way that's a hell of a way to fix it and make it damn near indestructible.staggs65 said:exactly, thought it was described pretty plainly if you read it.
Jeremy
devinzz1
might get a gallon of jb weld and chooch her down the hole and make it one solid 20lb shaft.
yeah good luck there..better tie a couple of cables to your ski's.You can steer that way..don't waste any time as the snow will be gone soon again,,lol
sleddineinar
Get some zip ties and zip tie it back on... that'll hold it good enough for this season.
Devilin AblueDress!
Get 2 18" pipe wrenches, One to go left one for going right!
devinzz1
blue blue blue BLUE! stop interfering with my dreams of a 4 season winter!
I like the pipe wrench deal..do it..fast,,hurry,,snow is melting as we type.I am going out for a ride tomorrow.Took off my expensive shaper bars from the ski's and put on the stock runners that came with them.Then I won't feel so bad about losing some carbides when I try to get to the River..
bluewho
I used to snapem off on my older yamis bye.What i found is never turn the bars when the sled is sitting,,,,git off and turn the skis with yer paw or do it under power and you will never snap a steering post top again.
devinzz1
blizzard outside!!! got 6" 1/2" tube got 1/4 carbon steel wire for wear bars. AHHHHHUUUUGGGGHHH
