devinzz1
how do i set belt alignment for a 97 vmax 700 sx. goin on trip in an hour or so!!!
Thanks!
Thanks!
here is a process to follow,but you will need a clutch Pro alignment tool....
http://www.totallyamaha.com/snowmobiles/aaTECH/Clutchparts/engine_install_and_clutch_alignm.htm
and here is belt deflection process
http://www.totallyamaha.com/snowmobiles/aaTECH/belts/beltdeflect.htm
devinzz1
who needs a clutch alignment tool when you got a machete, cable ties, and c clamps! Belt exploded at WOT last night and EXPLODED! braaaaaaaaBOOOMCLANKCLANKCLANKSNAPBZZZZZZZZZZ
RIP mr belt!!!
devinzz1
bluemonster1 said:RIP mr belt!!!
RIP speedometer cable
yep.my speedo cable and belt are buried somewhere from when that happened to me on my 600..lol..but I was using an after market friggin belt also..
ski_doo1200
Devin,
Question for you. I have the same sled - 97 SX 700. Do you know, or can you tell me, if your 2ndary clutch has any freeplay? I can move mine about a 1/4 to 1/2" and I don't think that's right.
I have an awful grinding noise somewhere that I'm trying to diagnose.
Thanks,
Jim.
Thanks,
Jim.
Yes, the secondary should have some free play in it, not a 1/2" though, more like just under a 1/4". Check bearings for the grinding, chain case & drive axle.
devinzz1
^^^yep just a little free play. What belt are you running? if its the cheap max2 belt then thats your problem. had to get a cheap belt yesterday and my god! sounds like a j.a.k.e brake when decelerating, Where the yamaha/dayco belt just makes a slight buzz thats almost unnoticable
