bucky
98srx6
I believe that is a relay rod.
bucky
sounds right. Notice the other one is hitting also? The owner before me put the extra wheels in the wrong spot. They hit the hardware when compressed it seems.
98srx6
Gotta love previous owners.
Is that from hitting on the wheel itself or on a spacer, or other?
bucky
I believe the square part of the hardware...know what i am saying?
reddog mmax 700
relay rod
i'm 99 % sure it's a relay rod.
bucky
Anyone know where I can get one. Anyone got one for sale. Tried talking to dealers and they are not understanding me!!!
Srxspec
Your #1 performance shop!
Call the dealer and tell them you need to order a relay rod, part number 8CX-47494-01-00 you should replace the one that's gotten hit before it breaks as well.
Yamadogger
Relay Rod
Why not just weld it? Those rods are strictly under tension (assuming it's not hitting like yours was) so it doesn't need to be anything fancy. Pull it out and either weld it yourself or take to a local welder and have it done. Probably cost less than $10 and will be good as new. As long as it's out, beef up the other side and ride on.
bucky
What you don't see is the other half of the rod.
It looks like a friggin pretzel!!
Srxspec
Bucky, call Port-Yamaha (262-377-5480) located in WI and talk to Kevin or call F&S Yamaha (717-632-6382) located in PA and talk to Barry.
