gil7247
I'm putting my motor back together and I see they make 2 Yamabond's. Which one do I use when reassembling the crankcases? Or does anyone have another product that works better?
Thanks Guys
Gil
Thanks Guys
Gil
motorhead327
I use the grey.
staggs65
there are more than 2. you want 4 (not 4b)
I used Hondabond 4...which is gray
motorhead327
I think they are all 3 bond products, like what's on the mail order books!
A couple of bucks
Mopar is what I swear by.gil7247 said:Or does anyone have another product that works better?
YAMMIEGOD3:16
GRAY. 3:16 (yammie tony)
gil7247
Thanks guys Yamabond 4 it is thanks Staggs
If you don't have easy access to Yamabond you can use this stuff.http://www.permatex.com/products/mo...cle_MotoSeal_1_Ultimate_Gasket_Maker_Grey.htm
I get it from the local auto parts store but any place that sells permatex products should have it.
staggs65
fourbarrel said:If you don't have easy access to Yamabond you can use this stuff.http://www.permatex.com/products/mo...cle_MotoSeal_1_Ultimate_Gasket_Maker_Grey.htm
I've used that before too with no issues
gil7247
thanks for the tip on the permatex. Gil
No problem,I find it works every bit as good as Yamabond.I've sealed up a few cases with it and haven't had one leak yet.
