Who on this site is still selling these stavex double grip rivets? I would like to purchase 50. Please PM me. Maybe some backer washers if available.
Thanks.
Thanks.
I used buck rivets for my m10 install, worked awesome.Thats a great idea, tractor/trailer shops carry the rivets. There is a special buck rivet bit that fits in an air hammer. Then you use a block of steel on the backside to mushroom it over. Trailers are made of 1000's of these(van style).
I did that too. Reattached the grab bar to it and the extension.I went and bought some aluminum 1 1/2x 1 1/2 angle and attached them in the inside corners of the tunnel and tunnel extension for extra support. It hardly added any weight and I just used normal rivets in the tunnel extension since they weren't depended on as much for support. Seems to be holding up good.
Buck tools are as easy as a hammer and chunk of steel. Though air hammer with 1" or so blunt tool makes it easy peasyHave you considered 1/4" stainless screws/bolts, with nylock nuts? Used them to mount trailing end mounts on 97 SX700, used red loctite, been on there a long long time. 1/4 rivets and rivet tools are hard to find.
