figured out the problem, bad numbers. the numbers i gave are from your original mount hole and back, not the driveshaft back. i apologize. if you use your original bolt hole as your starting measuring point and then go the 9+" back for your new front arm hole, everything should work out. why the heck i wrote driveshaft on the template is beyond me unless it was for orientation. it will be corrected.
that should get you going back in a positive direction.
orchie18
Yeah makes sense dirt jumpers sketch seems to be correct I am making some new brackets and filing some holes
orchie18
I have the suspension in as to the measusrements everything looks good but the suspension wont move. For a small experiment i moved the rear sissor mount forward half an inch and i got a little bit of movement in the suspension. But as soon as i put the transfer rods in im back to square one, no movement. It seems as if the rear half of the suspension is to far back in tunnel. But the center mount is 13 3/8 back from the front mount. im kind of stumped and dont reall want to drill anymore holes in my tunnel if at all possible. I posted pics at a new post
