Pulled out the power valves to clean them today..... as I was cleaning the the ports on the motor with a pencil noticed that the eraser had fell off
(just the rubber part no metal) I looked all over for it, took the exaust manfold off and serched in there and the exaust port could not find it....if it is inside the motor do you think it will hurt it??? Or do I need to strip the motor down and find the stupid thing???
If it did go in the motor, it won't hurt anything. Just start it up and it will end up going out the exhaust. I've had plastic and rubber fall in during top end re-builds with no damage.
Thanks Lenn still does not give me a warm fuzzy feeling.
98srx6
Pull the head and get it out if it makes you feel better. Shouldnt take very long to do.
ecopter
Don't use a pencil/eraser. Use Q-tips instead dipped in carb cleaner. It takes a lot of them but it works much better.
Jon
Jon
Canuck
I use a piece of wooden dowel wrapped in a rag and sprayed with carb cleaner.
