oops!!! power valve cleaning
Rex
VIP Gold
Chicago Subs
Pulled out the power valves to clean them today..... as I was cleaning the the ports on the motor with a pencil noticed that the eraser had fell off :o|
(just the rubber part no metal) I looked all over for it, took the exaust manfold off and serched in there and the exaust port could not find it....if it is inside the motor do you think it will hurt it??? Or do I need to strip the motor down and find the stupid thing??? :o| :o|
If it did go in the motor, it won't hurt anything. Just start it up and it will end up going out the exhaust. I've had plastic and rubber fall in during top end re-builds with no damage.
Don't use a pencil/eraser. Use Q-tips instead dipped in carb cleaner. It takes a lot of them but it works much better.
Jon
