Hi, can anyone advise what size washer to adjust secondary on a 2000 sx700r ? And you ADD a washer to raise the belt, correct ? Thanks
Vtnaples said:Hi, can anyone advise what size washer to adjust secondary on a 2000 sx700r ? And you ADD a washer to raise the belt, correct ? Thanks
The factory adjustment washers are 1mm thick[.040"]
chris700readhead
Adding the washer does raise the belt it allows the sheaves to come closer together.
01sxr700
Washer, Plate (T=0.5) UR UN
90201-061H1-00
$1.11
Washer, Plate (T=1.0) UR UN
90201-06037-00 90201-06431-00
$0.99
They make them in .5 and 1 mm
90201-061H1-00
$1.11
$0.99
Thanks so much, how high doesnit raise the belt with either washer ?
Rustman
all I used were rivet washers, they are very cheap and very available. How much they raise the belt will depend on how worn your belt is and how worn the adjustment screws are. If the tips are worn off it may take a washer just to make up for that. then perhaps another to actually start to adjust the belt height. Is the belt new?
biglsells
Rustman, correct me if I am wrong but if the tips were worn off the adjustment screws would that not produce the same result as having no washer, allowing the sheaves to come closer togther and adding a washer at that point would do nothing?
The belt is brand new but sitting too low, and I belv u would add washers to raise, just curious how much a washer actually raises the belt
Rustman
biglsells said:Rustman, correct me if I am wrong but if the tips were worn off the adjustment screws would that not produce the same result as having no washer, allowing the sheaves to come closer togther and adding a washer at that point would do nothing?
No, I think you are right. sorry.
A couple of bucks
That brand new belt isn't a CH is it ?
