dewey
i have a issue my 07 venture what happens is it is hard to start almost drain the battery before it starts, once started and with the choke off it seems to idle a little rough, when the warm up light goes off i try to rev it up and it hesitates and either tries stalling or revs up to 5000 rpms and with pressure still on the throttle to try to hold the rpm at 5000 it starts to lose rpms(goes down to zero)and then stalls it starts right up again but continues to do the same thing. it happens with new plugs and then after this happens the plugs are fouled and wet, put new gas in all the time. this sled only has only 100 miles on it. Im hoping its something simple.
