Devilin AblueDress!
jmlarson686 said:I'm In buffalo grove. Took the bolt out, was fine not stripped or broke. The clutch popped right off. Noticed that it seemed like the bolt backed off a little or something. What do you have for it? Haven't tested it yet waiting for shims for the secondary it has a little play on the shaft.
WEIRD..posts 11-19 werent there when I started typing post 20....? "has a little play on the shaft" It should have some side to side play.
jmlarson686
I rode it about 400 miles last year no problems and the 100 miles on Sunday.
jmlarson686
Yeah it has a little side to side play. Should I not add a spacer?
jmlarson686
Once I tightened the retaining bolt every thing seems fine again. The clutch is tight, turns the motor over every time, has absolutely no wobble.
Devilin AblueDress!
jmlarson686 said:Yeah it has a little side to side play. Should I not add a spacer?
How much? If its less than 1/4 -3/16 of inch I wouldnt mess with it. Any more than that you should look into why? Jack shaft should have little to no side to side, secondary should slide on jackshaft a little bit. You need a lil for the secondary to self adjust so to speak.
jmlarson686
Oh I would say way less that a 1/4 inch maybe at most an 1/8" I would say around a 1/16" without measuring it.
