Finally got to get the sleds out ..sx fired right up on first pull ( 1st time that has happened). 500 vmaxx however, would not! Heres what i had......took plugs out and rolled over 15 times, ..put some gas down cylinders, and replaced plugs ..fired and died... repeated ...repeated , but it just would not stay running..checked plugs and replaced ..no go..repeated procedure..no go.. checked plugs and found them to be very wet..ok flooded? ...I got spark ,i got wet plugs.. but it wont fire till i put gas down the cylinders......whats my problem? anyone?
Plugged pilot jets? Fuel is not getting to the motor. Its running on the fuel you dump in the cylinders only. Take carbs off and clean them. If you still have the problem then check fuel pump.
Rustman
fuel pump or lines i would say..pulse line is where I would start
Devilin AblueDress!
Any differance between no/half/full choke? If its trying while choked would point more towards pilots.
no diff in choke pos. sled wouldnt stay running long enuff to check anyway.
Vmax540
"Wet plugs" Old gas in the bottom of engine and/or in pipes ?
FF-Tony
gonna stick with this thread, having exact same problem with the exact same sled, only thing diff I'm doing is took off the last section of exhaust and gonna take it to work and see if I can air through it with a air comp. When I start mine with fuel down the cylinders the next pull I get a back fire and chunks of snow...
thefindian
With this junk gas we got now days you got to clean the carbs every year before you even put your hand on the key, or take a chance melting a piston.
yammy said:no diff in choke pos. sled wouldnt stay running long enuff to check anyway.
Did you clean your carbs? Give us some info so we can help you out.
this is more of a trivia question, as I have already figured it out! Come on people ..whats the answer? This is the first time somthin like this has ever happened to me!
staggs65
id say out of gas but plugs wet
super1c
Super Moderator
Kill switch on?
super1c
Super Moderator
Oh wait u said it had spark. Hmmmm
staggs65
whats the prize for this trivia contest anyways?
viper44
Clean Carbs First.
viper44
2 Funny
SRX500kid
I give up. I have same sled but never had a problem like that.
sleddineinar
I'm going with either out of gas or had gas shut off.
Yepp, going with out of gas also! Wet plugs from dumping raw fuel down the cylinders
