nelsonhouse
i am running an 8dn belt.
will this make any difference from an 8ch belt?
yammy said:running the 8ch will lower your shift out rpms! You need to take some weight out of those clickers ,they are to heavy! you should be running around 42-43 grams of weight and run those pipes around 9100-9300 rpm for max . performance!!also turn fuel screws out to 3 or put 50 pilots in er.
mrviper700 said:thats as close as your gonna get till you get a new red primary spring, you can lower the engagement down a bit by adding more washers, more heel weight will lower engagement speed. Your top speed is a bit lower because you have the secondary clutch tighter.
I merely gave you options to use so you can at least ride it with somewhat power appllied, no other spring will match the red h/c one so buy 2 of those.
once you get your new spring in and your rear clutch set back to around 60-70 on snow it will run like its supposed to. In the meantime you can play with the heel weight as the engagement speed will be the same with the red and the grey they are both the same there, so add more washers to bolt to lower the engagement speed, right around 4000 rpm is good for snow, 4200 is fine if your hooking up no problem.
Theres 1 other band aid fix you can do is swap out the rear sec helix to one of 48-40,or 50-40 and that will raise up your rpm, and allow you to back off the sec spring tension to get better topend speed.
nelsonhouse said:I went for a ride today. I had a closer look a the rpms. Engagement is 4500 rpm.
Shift rpm is 9000 rpm on bare ice. I was thinking of removing the centre weight.
And adding more heel weight to bring the engagement back down to 4000 rpm.
How many feet or meters does it take a 700 sx with pipes to get to 9000 rpm.
I would try a helix with a more shallow finish angle to get it to shift @ 9000.nelsonhouse said:i checked out the secondary and it was at 80 degree twist. so i twisted the secondary to 90 just to see what would happen.And the engagement is still at 4500 rpm. i did not bother the heel weight. the shift is about 8700-8800 rpm after about 200 ft. then settles down to 8500-8600 rpm. this is testing out on the lake trails. the top speed is down a bit more. i'm going to change the twist back to 80 degrees. and it only climbs up to 9000 rpm on bare ice or on a really hard pack trail. there are only two locations with those conditions. the temp today is -8 C with light snow 1 inch. i am going to change the jetting as soon as my jets come in. the weather is going to be warmer now -10 C to -1 C. i think a tempa flow or a dial-a-jet would be great this time of year. the temp is going to change a lot from day to day.
