chikkenvoicesinmyhed
I need some advice on a topic which seems to come up on a few forums: the allen bolts on what I think is called the recoil housing or recoil catch (my manual arrives tomorrow... I'm going by what i read online and this is my first sled.. a 1999 MM 700 with a few seized bolts).
I've got a wheel balancer puller for the next step but this step is killing me as it's so easy for my allen bit socket to turn half way into the head of the allen bolt, which seems pretty soft. I've tried heating with a torch and I've got an impact driver as well as an electrical impact wrench. I've seen suggestions of jamming a torx bit in there, but unfortunately the right size to jam into the 5mm allen head would be T35 (T30 is not tight enough) which I can't seem to find (it's only Torx plus I hear).
I'm thinking if I keep trying I make the bolt head a little worse every time. The bolts aren't ruined yet. I have sprayed penetrating oil, 24 hours ago, maybe it's not long enough, but I've also read that it won't reach the threads... or is that for different bolts.
BTW this is for replacing a crankshaft. I guess this means I don't need to worry about ruining bearings..
