You all know lately I have been having issues with my PV cables.Got to a point I just want to sell the sled or part out.I am running stock clutching and my rpm's were about 8500 to 8600 on wide open pulls.If rpm dropped..I knew PV cable broke again..
So I have a guy who really wants my motor,but I don't want to pull it out..and there is the wiring to go with it and whatever.Told him I would want $3300 for whole sled or $2400 less skid,track and front Ohlin's.He offered me $2000.I said ok,then for $2000 I will also remove trailing arms,ski's,radius rods and steering arms.He came back with $2400..That is one story.
Now prior to this..I noticed the SRX was getting harder to start.Used to start in 4 to 6 pulls sitting for a week or two in the cold temps.Last week it took 50 friggin pulls..something not right here.Then one night I decided to scrub the clutch faces and put on another belt that was a little newer.Even changed the buttons to new stock ones on the 2ndary.Thought this should really pull now.Boy was I surprised.Motor sounded lame,wot on the river was only 8000 rpm.Now I am pissed and wandered what is going on.Rivets always had 5.5g tip and 4.9 inner.So after trying to reduce weight in the weights by drilling out a little at a time,after like 3 to 4 attempts..rpm wasn't coming up..now really getting pissed.Basically clutching is totally stock like from factory.well from previous years like this..it should be over reving like crazy..I was stumped.I had removed a total of 7 grams and rpm maybe came up to 8100-8200 max.So transfered rollers/weight to my other primary..no change. Switched 2ndary's..no change!! Now you can see why I was ready to dump this sled..Check my cables again,now center PV cable is starting to fray,but is still opening valve..so now after reading a post here of another member not getting his rpm's up either,Mrviper posted to him if the stator is not good,the SRX will not rev up past 8000.Well this is my issue I think.Of course that member switched stator's and his SRX is back to life again.I have a spare stator here as well.I even switched CDI and nothing changed.Now I have ordered 6 spare PV cables used,will be here probably early next week.Gonna get all that set up proper,and then will switch stators,will pull carbs and clean good and even pull reeds and check them.I am jetted up 1 size from stock this year and my plugs are a light color,thought they would be darker.No DCS flashing to this point.Now if the stator does wake her up again..then for the last few seasons..that will explain why I can't get the SRX performing well.If all this works..I may keep the sled,if not.that guy gets the sled for $2400 and I am done with it.There is only so much a guy can do already...maybe time to find something a little newer.
Will post results at a later date..have my doubts for now...
not a happy camper..
