dieselcamper01
95rxl650 said:Most likely took your bearings out last year.
If you have a heated place to work, anyone can do the job, although being your first time, you may do some cussing and kick shyte around the shop a few times.
If you decide to go ahead and do it, it can be done in a day providing you can get the parts you need same day.
Post up if your going to tackle it and we can walk you through it.
Biggest pain in the azz is getting the rear suspension in and out.
There are a few little tricks to make this step go smoothly. For me, it's a cinch strap. Not a ratchet, but one that uses a cam buckle. Much easier to make small adjustments to the height of your tunnel. This is suspended from your ceiling. The other is a crazy carpet. Most important tool.![]()
What in the world is a "crazy carpet"? I am going to be into all this in a few days and can use any pointers I can get. Not my first rodeo but it is still a pain in the arse every time.
