SRX_700 said:My front Ohlins are 213 mm (total length of spring) with 8 clicks out for dampening force. My Stopper Band is set at 32 mm (yours is at 20 mm which is less weight on skis, more weight transfer). My front mono is 190 mm and rear is 306 mm. Full rate adjuster is at "B" position.
So I guess I should be 1 click out on the front shocks for dampening force and stopper band should be 20 instead of 32?
Sled as is handles like crap.
Doug,
Can you do me a favour and check your specs and see how they compare to mine? I am a 190 lbs rider. I am going to change the limiter straps to 20 mm from 32mm. What else is different with your setup compared to my stock settings? Thanks Doug. I want a starting point.
