staggs65
I'm sure you can use the shaft no problem. just need to get the measurements for the holes from somebody.
Im guessing that measurement is not extremely critical (within a 1/4"). I have a friend that has an attack i can get it off of. I'll just measure the outside bolt heads and not go through taking the skid out.
staggs65
let me know what you get for measures. After looking at the pics of musselman's it looks like it puts quite a bit more radius in the track around the rear wheels. I might use the shaft now too.
That was the biggest reason i wanted to keep the shaft. It will help keep the track closer to a circle (less resistance). The other was teh nice powder coating that I have and dont want to mess up. it looks like Im going to need brackets to mount it to as well because there isnt any tunnel to mount to where it will end up. I will probably look at my friends and make my own.
staggs65
it might still be in the tunnel on the Viper. I think the Viper tunnel is deeper back there then the four strokes
Looks good---I love how those red rails look!
03viperguy
Looking sweet! Red trails look pretty awesome
Sent from my DROID RAZR HD using Tapatalk
shaggyzr2
Lookin good! A red snow flap would look sharp on that sled.
super1c
Super Moderator
Bas A$$!!! The red sets it off, Looks like it fit in there just fine. Make sure you include all the info for the 136" install, would help out others im sure.
staggs65
looks good. I'd like to know the measures you used for the rear idlers.
Yeah sorry. Just "finished it" last night. There are a few things I ran into doing this but it all worked out in the end real well. I am going to go out for a test run this afternoon to make sure it rides good and stays together.
Ok...
It time for the write up I guess. I need to start by saying I used 03viperguy's write up as a starting point. I used his template for the mounting points which are the same on the attack (136) as they are on the apex (121) with the exception of the rear upper idler shaft. that gets mounted 7-7/8" back from the original hole that is reused for the new one as well. I used the apex reinforcement brackets and cut them to fit nicely in the tunnel.
i then marked the outline and removed all the rivets that were in the way. i drilled the main hole first and put the bolt in tight so i knew where to drill all the new rivet holes. I drilled as much as i could from the inside to keep the metal chips from getting in the engine area via the running board. Added all the rivets and removed the bolt. I then took measurements off of an attack to find the rear shaft location on made a small aluminum reinforcement bracket and riveted it on. I also had a friend make a couple items for me. A new idler shaft ( you can use the one from the proaction skid but it is steel and not painted), and 2 spacers. the spacers are needed because the attack's skid is mounted to drop brackets from the factory and they are more narrow than the tunnel. I cant remember exactly what size they were. i can dig it out though...
It is basically the same as the regular mono with a few changes. That is the quick and dirty. Ill edit it as i get more time. I think if i were to do it again, i might look into using the attack drop brackets to get a little more aggressive look. im not sure if they would work or not. Might be worth a look...
super1c
Super Moderator
Man Jason that's one bad a$$ looking viper! Makes me want to mono mine!
Man that look good, nice job
Its not real hard Chris. I can walk you through it real easy. Good summer project. I found the skid for $100. Came with the EC shock too! Bought the second EC shock for $75 from the same guy. That helped fund the rest!
03viperguy
That is a steal for a mono! And it is a pretty straight forward install, but you made it look GOOD lol
