shot helix?
im finalizing a deal for that multi angle helix and it should be here in a week or 2. I will change all bushings in my secondary to new ones. so my first question is whats the trick to remove the big fiber bushing if any at all and the reinstall? I have acess to a press just not sure how to press it in properly. and now for the set up I have no clue so any help would be grately appericated the sled is 100% stock. thank you -peter
PETE SET IT IN B-3 WHEN YOU FINALIZE THIS. THAT PRESS SHOULD WORK, BUT I WILL DOUBLE CHECK IN MY TECH MANUAL FOR YA. 3:16 (yammie tony)
i will also run the tall cover with the www spring. what should i exspect from these mods? my main objective is to get outta the hole a bit better im fine with the top end as it is now fast enough for me. just a little low end grunt would be nice.
