Robs96max4
Oh and 4 shims
yammieguy
Its no heel clicker then.
Robs96max4
Just hoping someone will tell me what spring I should be running with weights in it ( 89a-10 )
YAMMIEGOD3:16
i know you should not be running 4 shims. wow!!!!!! 3:16 (yammie tony)
Robs96max4
Lol tony I had a hard time compressing the cover to unscrew it
89a10 weights work good in a srx, maybe more of a lake running weight but still can be trail ridden with no problem, great topend. I would use a differnt helix then stock though, the 47 would be kinda flat, need something more like a 50/36-51/38 with them.
likely has all those shims to try and raise topend rpm as the 47 is too much laod for the weight of the 89a10s tip.
Robs96max4
Awesome thanks, would anyone have 1 of the helixs ^^^
YAMMIEGOD3:16
Rob I Have To Check. I Might Have A Extra 48-42. Angles Don Listed Work Nice For Racing. I Know I Can,t Part With Those. 3:16 (yammie Tony)
yammieguy
You would have better luck finding a stock 51/43 helix
89a 10's not the best back shift..
let me look to see what i have on the shelf helixwise. The 89a10s work pretty decent with a shallower finish, the backshift isnt too bad that way. They feel about the same as 8bu-00 for backshift with a shallower finish angle in the combo.
YAMMIEGOD3:16
BEST I HAVE FOR ROB TO SELL IS A 47-43 HAUCK. ALL MY SHALLOWER CAMS ARE KEEPERS. 3:16 (yammie tony)
