Roller Size Engagement Change
BornYamaha
Northern IL
How much would you expect going from a 15mm to 16mm, or even 15.6mm would raise the engagement on a xtc 500. It already has a primary spring with a slightly higher preload and stock weights. This pushed it from about 3900 engagement to about 4300 engagement. I already have the max amount of engagement springs installed. Would you expect 15 to 16 be a small like 100 - 200 rpms or something more dramatic like 400 to 500 rpms. I want to get a set to play with but I am not sure if I want to try the 15.6s first or go straight to the 16s. I know it will have some effect on the rest of the range but I will compensate if need be. If you look at an old dyno chart on this site you can see why it is a struggle to get these things to take off very hard. They have very little power on the low end. Any experience would be appreciated.
get rid of your stock weights and go to 8ab weights. that have a aggressive profile and will increse your engagement. you can probley run them pretty lite. 3:16 (YAMMIE TONY)
When I go to the sled specs here it says I already have 8ab weights. We are the original owners so I know they have not been changed. "98 XTC 500"
ok cool the xtc came with 8ab. i would not change rollers. get different spring for your primary. 4500 where ya need to be. try the srx y-w-y . 3:16 (YAMMIE TONY)
low engagement sounds like a sacked spring. Not putting a pile of engagement shims.
The original spring was a W-P-W 30 Preload/2.25 Rate. Last year I installed a W-S-W 35 Preload/2.25 Rate. It was new from Yamaha so I don't think it would be sacked but it was a nice thought. It helped some but I would like more. I only use 3 shims so I think that is the most recommended and alright. This is a "98" machine so from the info I have gathered here on TY this has the "Short Cover Primary" so I do not believe I can use the Y-W-Y 45 Preload/2.5 Rate "Tall Cover Spring" Please correct me if I am wrong on this. It would make my life easier. If I could use tall cover springs I was actually considering the B-W-B 45 Preload/2.0 Rate since the "total force" number is closer to what I have so I would think I would need to change less to keep my shift where I want it. Can you just put a "Tall Cover" on an originally "Short Cover" clutch or is there more to it than that?
You can put a tall cover on it with no prob Just keep your X's lined up 15.6's will up it yes.
