bco2jco
My 2001 sxr700 speedo stopped working. Yes the key is broken off in the shaft. I loosened the set screws and was able to slide the bearing off the end of the axle. My question is: How do I tell if this bearing needs replaced??
There was no obvious damage to it, the seals were in place and in good condition. I cleaned it up with some Brakleen and it spins and turns freely. What is the criteria to determine if it is still usable? I could just get a new one since I went to the trouble to remove it, but if its still good that seems like a waste of $30. Is this bearing (UB205 Nsk) available aftermarket or will I need to visit the dealer. Also what are your favorite places for OEM discount parts online? I am still trying to get the broken key out of the axel shaft, I am hoping I can do this without removing the entire axle.
roudyroy1
take the seals off, look and see if the grease is orange or there is water. since your spedo key is broken i wold say it needs to be replaced. if not just do it anyways well its off. i put an ntn one i my sled, and its holding up so i would trust it. if you pack them every year they will last forever.
sleddineinar
I've been able to pick broken keys out with a dental pick, or a small drill bit.
ALLSEASONRIDER
Got mine with a drywall screw...replace the bearing since you are that far into it
You will be glad you did.
bco2jco
roudyroy1 said:take the seals off, look and see if the grease is orange or there is water. since your spedo key is broken i wold say it needs to be replaced. if not just do it anyways well its off. i put an ntn one i my sled, and its holding up so i would trust it. if you pack them every year they will last forever.
There was not water inside but the grease looked like chocolate so I guess I should replace since I have have it apart. I might add the zerk fitting that I read about in previous searched posts.
Does anyone know if this bearing is available aftermarket or only through a dealer? The one I removed is NSK UB205, and I think NTN ***205NR, is the same.
Thanks for everyones help. I will try again tomorrow to remove the broken key.
roudyroy1
yeah i think ntn is after market. find a industrial bearing distributor, thats what i did and got it cheap. or a bearing specialist, and they can find you a equivalent.
Roudy is correct, if you take your bearing to a industrial bearing dealer/supplier they will measure it and even cross reference with other bearing manufacturers. There is not only one company that makes any one certain type of bearing. I have done this in the past. Good Luck.
A couple of bucks
ALL BALLS speedo bearings have been put in all of ours. Good shtuff.
