So im new to this site and new to sledding. I just got my first sled, and that is a 1997 yamaha mm600 twin. Anyways i was out riding today and was at it for 4 or so hours and when i came back home for the day the sled started acting up. when i rolled in to park it the sled wouldnt stop driving, it wouldnt go into neutral and it eventually stalled when i put brake on to stop. so i tried starting it and it was still engaged in drive. the only way i could get it to be in neutral was if i pulled on the belt to spread the plates to loosen the belt up then it would start and idle. then id drive and it wouldnt go back into neutral. so its apparent theres a drive/clutch problem. when i got looking the primary clutch/clutch mounted to the crank came apart. there are 3 or 4 pieces that broke apart. they are alluminum and have 2 pieces of wear material on each side. i want to say there guides to keep the outer pulley half inline but not sure. the outer pulley half also is missing a chunk of aluminum.
So my questions are:
1) Do i need a whole new clutch with that much damage?
2) are there better aftermarket clutches to get?
3)how much is a clutch going to run me?
4) when i was riding my clutch was engaging at 2500rm, is that right?
5) it would only rev up to 6000 and do about 90km/h, does that seem right for a mm600 twin?
6) if i get a new clutch will it need to be tuned?
Sorry for all the questions but i hope someone can help me out. any help will be appreciated thanks. just want to get back to riding.
