superfan75
I know there have been some posts on here about not getting top RPM. My Viper only will run up to 8000 RPM, even with it on a stand. I have cleaned the carbs and cleaned and adjusted the PV's. I checked the wiring harness and protected it with wire loom protector. I didn't see any rub throughs in the wiring harness. The machine starts and runs pretty good and has a full tank of fresh ethanol free gas. It has new plugs and it looks like it has good spark in all three cylinders and there are no warning lights lit up. I was thinking of pulling the reeds since the previous owner installed V Force 3 reeds and it sounds like its common for these to split or crack. I was also thinking I should check the flywheel for rust. I'm just not sure if either of these things would cause the symptoms I have. It would seem that the reeds or a rusty flywheel would make for a hard starting bad running sled. I was wondering if someone had a good suggestion before I check it out this weekend. Thanx.
