staggs65
It has an aftermarket belt deflection adjuster on it, not sure how those work but i'm just guessing you don't use the 3 bolts with that.
I am going to keep following this, i just bought heel clickers for my sled and asked Mr.Viper (which i appreciate his time) countless times on my clutching because ever since i put the darn things in my clutch it bogs. I followed his cake recipe and kept pulling weight out the fly weights and started thinking something else is wrong and i know there is. It bogs out bad, check compression and my power valves all are good.
I did get all the stock jets in it, both the mains and pilot jets and I have my needle at 3.25. I checked the stator again tonight with the engine warmed up good. On the three white wires I got .7 ohms and on the pulser coil I got 223 ohms and I could still get 7 - 9 VAC depending how fast I pulled it over. I was going to try my brothers clutches tonight but its pouring rain out. So MrViper you think my belt might have something to do with it. The belt that's on it is new, but I do have a new Yamaha belt for a spare. This is starting to seem like a puzzle. So far everything I checked seems to be fine.
ya but it doesnt look like a 8dn belt,looks like a aftermarket belt.
Well I tried my 8dn 01 belt tonight and I was seeing somewhere around 8500 to 9000 for the short WOT I could pull. Damn was it impressive with the 53/43 helix and green dot spring. It was hard to get a good pull because it was lifting the skis in the air and its not exactly smooth up in my field either and its not very big. I washed my belt first and tried to warm it up good before a WOT run and I tried to smoothly give it the throttle since the belt was new. After a while though I couldn't get the RPM anymore and it wasn't much higher than 8000 again. So when I parked it I checked to see how hot the clutches were and hot and the belt was pretty hot to. I don't know if this means something is off or it was do to the short runs and then turning the sled around for another run, so there was slow and high speed together. I pulled my primary off to check it out closer I checked to see if it had the right size rollers and it seems to, they measured 14.5 mm. There was a little bit of play in the spider assembly. I'm not sure how much is normal. It would sort of bind a little when opening and closing the clutch, but if I put the cover on to stabilize it it seemed to be smooth. It seems nice though I think we're on the right track and real close to having it figured out.
