superfan75
Well I took my sled out tonight and I didn't really get consistent results. It would pull 8500rpms sometimes, but not every time. It didn't seem to change the more I rode it when the engine got hot. The temp was cooler tonight and the snow was better, maybe that's why it didn't do exactly the same thing as last night. On the steepest part of my field when it hit 8500rpm it would drop back to 8000 just before I had to let off at the top. Then on the flatter top part of the field it would sometimes hit 8500 rpm and sometimes only 8000rpm. I tried it with the hand and thumb warmers on and off and it didn't seem to make any difference. I would've unplugged the headlight, but by the time I get home its dark out. It's very encouraging to even hit 8500rpm since it hasn't done that since I've owned it. So I'm not sure if this is a clutching problem of a stator issue. It sounds like what some people have these symptoms with either. I wish we had some snow so I could do a proper test instead of these short WOT runs, but I guess this is better than nothing.
