jabber800
If your running in a pro event and speed tracks are allowed you should make the investment and run the same studs you had planned to run. Penetration will be just over 1/2 ".
If you run the 1.075 studs in the track you have I doubt you will hook up! As the track gets rutted things will get worst.
