When I go full throttle on my 01 srx 700 it'll get up to 8500rpm for about 50ft at the most and then it will bog down to 8000rpm and not pull as hard. Powervalves and cables are all good and clean and set to the right specs. Running BR9ECS plugs and they look good. 125psi on all 3 cylinders. Replaced the front left motor mount cause the left side of the motor was shaking bad and that hasn't cleared it up yet. Everything in the primary and secondary seem good, going to try to put a clutch kit in it Tuesday and see if that helps. Does anybody have any input on what my problem could be why it goes to 8500rpm then bogs to 8000rpm after 50ft? Any help is greatly appreciated, I can't seem to figure it out! Thanks!
