srxz
I haven't been here for a while but could use some ideas on this as it's turning into a nightmare lol!
Last year near the end of the season after a long wide open pull on the lake the sled starts to lose power.....getting off the gas to slow down and pinning it again there is full power once again only until you hold it wfo for some time does it start to bog........replaced fuel pump with used one to try.....no change...end of season!
This year I checked all the fuel lines, vents, new filter, another set of carbs and another fuel pump and the problem is getting worse.......float bowls are nearly mt when i check after the sleds starts to fail and will only run on full choke.......it starts fine still and runs good till its ridden for about 5 minutes.....also i experimented with an electic fuel pump temp set up to make sure the floats were full and sled ran fine with no issues!!
Thats 3 fuel pumps i've tried and 2 different sets of carbs so not sure why else it would run low on fuel in the bowls unless not getting enough pulse from engine but the line looks fine and it will fill the bowls from dry on a cold start!!??
Thanks guys if you have any ideas I don't what else to check??
