Not sure what to think here now......I changed the pick up line in the tank but had to put an inline filter on the end of it till the stock filter comes in at the dealer.....hooked the stock fuel pump back up and fired it up no problem and road around slow for a while then went out on the bay back and forth going fast but not wide open as it was rough then went up the road wide open and back and all was good no issues was very happy bit after about half hour of running it it started to bog again and eventually stalled!!!!!
Would not fire until I walked home and got some gas to bring back to spray in spark plug holes then fired right up and ran fine all the way back to the house!!??? Unless there is something in the tank that I can't see floating around I'm out of things to try......gonna fill the tank back up and see how far it will go on the trail this weekend when I get my try our trails free pass this weekend!!
In your first post you said you replaced the filter yet you now say you installed an inline filter. Is it plastic and perhaps floating or isn't positioned at the rear of the tank? Even though it's submerged it may still have a trapped bubble making it float.
