I have not had this happen but I seem to recall a thread or two on it earlier this winter. Did you run a search for your issue here in the Vmax section, as well as the SRX section even though the sleds are different, there is a lot more activity over there and many times the info can apply directly or at least set you in a good direction.
Have the carbs been properly cleaned and adjusted this season? It's not the answer to all the running issues out there, but clean carbs sure fixes a lot of them. On the flipside, there are a lot of engines burning down this winter, and a dirty/plugged carb is one of the reasons.
