bolt size to pull clutch w water method?
tnc110
VIP Lifetime Member
NC
If I understand this method correctly, you remove the clutch bolt, put the sled on its side, fill the hole with water and tighten a teflon tape wrapped bolt until it pops off. Question is what size bolt must be used? Also, what size bolt for a polaris primary. I have to pull a yamaha and polaris clutch.
Thanks!
Thanks!
Use the clutchbolt.
restOTE=SHARK;651458]Use the clutchbolt.[/QUOTE]
that works on doos, but not the rest
