If I understand this method correctly, you remove the clutch bolt, put the sled on its side, fill the hole with water and tighten a teflon tape wrapped bolt until it pops off. Question is what size bolt must be used? Also, what size bolt for a polaris primary. I have to pull a yamaha and polaris clutch.
Thanks!
Thanks!
Thanks!
Use the clutchbolt.
chris700readhead
The clutch bolt won't work it screws into the crank and won't create the hydraulic effect I use my clutch puller along with water, works like a champ.
restOTE=SHARK;651458]Use the clutchbolt.[/QUOTE]
that works on doos, but not the rest
do you know the thread size and pitch of the pullr
18mm x 1.5 pitch
fastsrx
Yamaha puller 18x1.50
polaris 3/4x16
polaris 3/4x16
