Ultimax
I was hoping someone could help me out. The factory kill switch on my sled needs to be replaced. I can't get the switch out because the red stop button needs to be removed and I can't figure out how to get it off the switch without breaking it. Does anyone know how to remove the stop button from the switch itself? Thanks
devinzz1
is there a screw under the red sticker?
Ultimax
Kill Switch
It doesn't look like it's removable but I will take a sharp knife and see if I can remove it. Thanks
devinzz1
Dont know for sure but the image of the button and screw came to mind when i read it ahaha. I will have a quick look at it tomorrow but i believe its like the high/low beam switch.
Sent
kill switch does have a removable sticker. be careful, its a thin aluminum affair and bends easily. you can flatten it back out if your patient. yes, there is a screw under there, #1 phillips. use some 3m 77 aerosol or tube type weatherstrip adhesive for the re-install.
Anyone know of a place to get a replacement foil sticker for the kill switch?
A couple of bucks
There is different colored foil tape or duct tape or that matter. Farm & Fleet has a wide variety. You could always make one out of some can lid in your recyclables. Mabey a sardine,kipper or spam lid? Grab your tin snips an go to town.
a knowledgeable dealer will have the part number for the replacement decal/cover. i may have it somewhere if you exhaust all your resources.
