Hi,
I was getting my sled (2001 SXR600) ready for the summer and for the heck of it decided to check the compression. All 3 cylinders were exactly the same and all at 100 psi. The weird thing is it runs great and only has 1800 miles on it. The engine has never been apart, all stock. The engine is completely dry and clean, no signs of any leaks of the head or base gaskets.
When I did the test, the engine was slightly warm and I had the throttle wide open and pulled about 7 times, until the gauge stopped going up.
I checked my pressure gauge at work and it is right on.
Should I just keep riding it (next winter) or what?
It seems to use alot of oil, could the rings be sticky? Is there a way to check that? Maybe WD40 in cylinders and repeat test?
Any ideas?
Jim in MN
Any ideas?
Jim in MN
