roudyroy1
No should gain top end
Any downfalls to this clutch set up?
We were out in -40 last year, and when your 200km from a large town you don't know what your getting for fuel. so the head gasket and jets will stay stock for peace of mind. Silencer will be done, I'm just worried about how loud it will be. I made my own reed spacers out of aluminum plate. Just traced the gasket and scrolled it out with a jig saw. Took a while to do. Royal distributing sells them.
what was the thickness of the aluminum plate you used cause really want to make my own also
Drop one tooth still works with stock chain 8df weights Stock 4.5 inner 3.6 outer and a 51/43 helix with green spring 70-80 deg
Little change in rpm and back shift is the big one
powder heavy snow more wrap/ packed trail 10* less
Do it only if you want to change jets almost every time you ride.How temperamental is the airbox mod?
