head and cylinder torque pattern and specs
jipcee
Chicago
Hey all, I'm working on a friends 95 vmax 800. Can anyone tell me the head torque pattern and specs. also cylinder nut torque?
Thanks in advance..........
base bolts are 20 ft-lb. the head bolts 16 ft-lb. each set of two heads has sequence. go side to side when torqueing. #1 bolt will be first bolt in middle of head, #2 will be on other head at front. and so on. there are 10 nuts total per head set. 3:16 (yammie tony)
try and follow me. on your diagram .
1 is your 5
2 is your 10
3 is your 9
4 is your 8
5 is your 1
6 is your 4
7 is your 2
8 is your 3
9 is your 4
10 is your 7
3:16 (yammie tony)
Got it! Thank you! Do you happen to know the ring end gap?
Thanks again..............
End Gap(installed)
Top ring -.35-.55mm
2nd ring- .35-.55mm
Side clearance
Top ring .02-.06mm
2nd ring-.02-.06mm
This is straight from the Yamaha service manual. Happened to have it out as I'm reassembling my 800.
