Here are some pics
so heres the pics of my front heat exchanger. The bottom two rivets are loose. The one i have My finger near in first pic. Is it possible to pop that rivet out and put in the opposite way or will this not work? I may just end up welding this in place instead of take everything apart to get at all rivets.![]()
my exchanger its self wasnt loose, but the bulkhead it was mounted to was. if i looked under the motor i could see that plate separated from the belly pan or what ever its called. when my sled was on the ground if the skis were held and i put pressure on the bars i could get it to move. scary stuff.
Hey is this sled you made the thread about still doing well with this issue?
Here are some pics
