Johnnyblazer
Hey guys, I have a vmax sx. And I'm having a vibration at low rpm. When I hit the brakes it goes away. Someone said it might be a fairing? Any ideas. Thanks in advance
couple things to check:
1.) belt- check to see if it has hour galssed sides, or try a differnt spare and see if problem persist.
2.) brake rotor on jackshaft, sometimes they get loose on the keyway, (take off caliper )grab it and see if it rocks forward and backward on shaft.
3.) track misaligned and rubbing on track clips, see if the track is running even from side to side.
It's definitely not the belt and it only happens sometimes.
