Thats the tors switch kicking, its the 2 wires that come off the center of the carb rack, you have the throttle cable adjusted too tight, you need to loosen up the adjuster and give it some slack.
Yep..And by non contact thermostat? Would an infrared temp gun work?
That's torrs! Throttle override system. Your throttle cable is to tight, it needs some slack to work. Try loosening it. You can bypass the system but it's not recommended, by the carbs you will see a switch on then idle stop, fallow the wires and plug the ones coming from the main harness into each other, that will bypass the system for testing.https://vimeo.com/114296670
This is a video of what it sounds like after I run it full therottle for a 100 yard run. As soon as I let it idle of a second. It's good to go. And every once and a while It sounds like it has a small backfire when I'm driving slow.
https://vimeo.com/114280069
Now it doesn't start 1 pull anymore. Now it's like 6. And it sounds like a mean cam... Any ideas?
not the idle screw the cable adjuster that threads into the top of the bracket you have the cable set too tight and its making the throttle over ride switch kick in. loosen up the adjuster, screw it in further into the metal bracket, not the idle speed screw ,the cable adjsuter.
I this video it just idling correct? Look at how the motor is jumping maybe that's your camcorder skills or I am missing something.
In your last video I agree with them. tors.
Throttle cable...t.o.r.s. kicks in at 3k rpms. U should have 2.5 mm of freeplay in your throttle cable. link how to clean your tors
http://www.totallyamaha.com/snowmobiles/aaTECH/TechIndex/Engine.html
the reason the engine is jumping is because the tors system is activating, its doing what its supposed to do. When activated it limits the rpm of the engine by cutting the spark, a rpm limiter if you want to call it that, and it sounds like it misfires because it does,
Loosen up the jam nut(10mm) on the adjuster, and screw the adjuster down into the bracket you need alot of slack. If you go and look up at your throttle lever and move it slowly youll see it will move towards the inside as it moves on the pivot, will look like its worn out as it moves on the pivot . It has a switch in the throttle block and a switch down on the carb rack. These two switchs work in conjunction with each other.
to set the idle speed you use the screw on top of the carb rack turn it down to raise the idle speed once you have loosened up the cable adjuster, set it to about 1500-1800rpm when warm.
you dont need to take anything else apart on the sled, its a simple couple of adjustments is all, theres nothing wrong with the sled. With all due respect intended, I know everyone is just trying to help you but you have been tearing things down and stuff for no real reason other then guesses and misdiagnosis. The motor mounts are fine, its the tors adjustment is all thats wrong now that you have cleaned the carbs and changed the belt.
Mr viper I Just want to double check this your saying the tors are activated at an idle as well?? From start up and limits the rpms to say 3000 ??
I must have had a misunderstanding from I have read on here about them. and where they activate. So I apologize. I guess I thought it would idle fine just not rev past 3000 rpms. So please get me straightened out on them.
The idle screw is right there by the throttle cable its a flat head with a spring under it. you can usually turn it with your fingures.
Sure there is if I understood the tors correctly a page of this post could have been avoided. My bad. I reseached it once the first time I cleaned my carbs I had the cable to tight. Guess I read some bad info. The other thing I dont understand is why he was able to run it around the yard a little bit and a 100 yards full throttle before the tors started working?? Now I am just curious. Would it because the sled has been sitting for a while and just took a little bit for the contacts to work again/clean them self. Something like that.
