Snowman74
A balloon would make me even more angry... Throw it as hard as you can and it goes nowhere. [emoji35] I'm going to have to use that Nerf ball idea at least then you'll get a good accomplished smack sound.A whole shelf devoted to carb cleaner
A set of extra long standard and Phillips head screw drivers.
And something to throw when it's not going good, Nerf ball, ballon, etc
Batwolf
Anyone ever buy a flywheel puller? The yamaha brand tool is $300+; I found a SLP heavy-duty puller on Dennis Kirk that is a "possible match" for my sled; its only $60. I suspect it will work since bolt patterns are mildly universal. What do you guys think?
staggs65
the universal harmonic balancer pullers from any autoparts store work
Impact driver with bits, a good one(mine is Snap-on)
Various length prybars(strikable)
Line-up bars
Lady slippers or what ever you call them
90% of my tools are snap-on(former heavy truck tech)
If you break any, email them and a replacement will be on the way.
Someone mentioned long screw drivers, I think Menards has the longest I've seen
4 1/2" angle grinder with grinding wheels and cutoff wheels
set of small picks
Line-up bars
set of small picks
A few more tools I like to use. The ratchets are good for getting at bolts you normally cant because something is in the way. A round swiveling head ratchet and an indexing ratchet. The indexing one is very nice, you wouldn't believe some of the bolts you can get to with that. I don't like the flex head ones as they are clumsy.
The Precision Instruments torque wrench. I have the 1/2" and the 3/8". They make them for Snap-On. You can get them on Amazon
Limited access bit set, great to get at those hidden screws.
Other than basic hand tools an over head hoist is a must in our shop. Ours is 14' high, we can pick up the entire sled and lift over our heads for easy suspension work, greasing the linkages ect. Next is the custom builts sled stand. This allows us to work on the engine, clutches ect. at optimal height to not have to bend over and such. Plus we can leave the sled on the stand and roll around the shop, we even store sleds on these stands. Al
