Yamaha vmax 600 gyt pipes carb specs?
A couple of bucks - from what I can tell that jet is for a motorcycle carb, and the way its made looks different to our carbs I think. Where the treads are? And the fact that it's from a 95. Apparently only the 96 vmaxs were equipped with the proper q8 jets? But is that all 96 models or just specific ones?
Check out this eBay listing I found. Using the parts diagram for a 1996 vmax I looked up the part number for the nozzle. The number is 8ay-14141-58. Doesn't say if its q8, but EBay listing that couple of bucks posted is part number 3tc-14141-58 and it confirms it's a q8. So because it's just the first 3 characters changing I'm thinking the 8ay is still a q8, and that 3tc is just a different type of q8? Who agrees?
eBay listing 321620750759
Unfortunately the parts diagram doesn't say how many of these nozzles are required per machine.
Here is a nice shim kit on eBay. It's not exactly 0.4 mm. 0.4 mm in inches is 0.015. The kit comes with .010, .020, and 0.30 shims. So I guess with this kit you can use either a .010 or .020 shim. A bit richer or a bit leaner. Probably won't be able to tell the difference.
eBay listing 110604954045
Ok just asking. I thought octane levels only had to be raised if compression was going to be raised.
