Just pulled the harness back as you said, there were 3 wires that had been repaired, I checked and they are all ok, no other rubbing thru, I had some red convulate in the shop, put it back together, same problem. I'm wondering if the pickup cool has adjustment for distance away from the flywheel? I had that apart earlier this yr doing crank seals and never measured it with a feeler gauge... What should it be set at if it does have adjustment?
Looking at your first post again, I'd have a look at the mag side crank seal or for some kind of crankcase leak. I've never had much luck testing one by spraying it. Mag side that is.
