SRX7
I get the dreaded red X
SRX7
pasted
"New Rider forward
Fuel Injection
Wider Ski Stance"
"New Rider forward
Fuel Injection
Wider Ski Stance"
WOW!!! Nice find Doc. The link works for me. Someone at Yamaha's web site department is gonna be in deep s**t when they find we are looking at this.
DoktorC said:
RedlineViper
anybody get to see it yet?
Dfunkdf
could just be a tease might be done on purposevice108 said:WOW!!! Nice find Doc. The link works for me. Someone at Yamaha's web site department is gonna be in deep s**t when they find we are looking at this.
Good point - apple computer does that all the time.
Dfunkdf said:could just be a tease might be done on purpose
DoktorC
I'm pretty sure they do it on purpose..seems to happen every year...
SRX7
bate and switch.Bring it on I hope it is a nice SnoX sled so "NS" can eat shit on AMsnow
Dfunkdf
"ns"???SRX7 said:bate and switch.Bring it on I hope it is a nice SnoX sled so "NS" can eat shit on AMsnow
SRX7
SRX7
shit didn't work,sorry guys.
SRX7
Dfunkdf said:"ns"???
northern skunk,he is a dick head
Dfunkdf
o icSRX7 said:northern skunk,he is a dick head
SRX7
More info
Because power-to-weight ratios improve with power enhancement and weight reductions, Apex is an example of the highest tech materials: CF die-cast aluminum Deltabox II frame, titanium exhaust headers, and magnesium valve and chaincase covers. Lightweight hood and aluminum tunnel. Less weight. More power. Greater power-to-weight ratio for terrific on-trail performance.
All-new cockpit makes the rider the center of attention. Taller seat with rear bun and raised handlebars position the rider forward for improved on-trail command. Wide boot-friendly footrests complete the rider-friendly cockpit.
Standard high-torque starter motor means quick, dependable go-power on the coldest mornings. Computerized fuel-injection means no choke. Simply twist the ignition key. Quick. Convenient. Standard.
Four-piston brake caliper and matched, lightweight rotor reduce overall weight while improving both cooling and brake response.
Mono-Shock RA features 46mm aluminum shock body with high-pressure gas damping.
Plastic skis with direct-connect to the wishbone-front suspension are lighter overall and reduce unsprung weight.
A - GENESIS 150FI
Fuel injection controlled by your throttle thumb and Apex's onboard computer. Crisp. Clean. Fuel efficient. Double-overhead cams, 20 valves. And four-stroke advantages of torque, smooth power, durability and now — fuel injection.
B - MONO-SHOCK RA
Dial in your own set-up with this exclusive mono-shock rear suspension's 20 clicks of remote adjustment that fine-tunes your ride for existing trail conditions. This suspension is as easy to tune as 1-2-3.
C - DOUBLE-WISHBONE FRONT SUSPENSION
New geometry provides super-precise handling; zero bump steer means flat cornering and sure-footed control in sweepers and tight, reverse camber turns.
A - GENESIS 150FI
B - MONO-SHOCK RA
BlueIronRanger
- Nov 26, 2003
I want to here more about the 800cc twin!!!
RedlineViper
still want pics too!!! damn... i hate this wait every year
Well
Gettin back to my comments on what would be/could be coming, I did not mean to compare the SRX to the RX-1. I was talking "model". SX, SRX, SX-R, all these have a long tradition in Yamaha and the SRX is on top as (i think) the best sled Yamaha ever made for comparable time periods. So, I would want that again, not some behemoth that says 4 stroke, but gets waxed every time to line it up with a comparable sled from XYZ.
Like the news form Canada says, power to weight. We'll see when all the hype settles. Gonna spring check in March 07.
BigMac
We'll know on Feb 7th, but reading the local Yamaha rep, the Apex is a "rider-forward" (as in Rev-style chassis) 4-stroke with fuel injection and*maybe* a monoshock rear skid.
RX-Eskimo
06 Yamaha Rumour
So, is the racer on the Japanese site close to this Apex design? The picture there seems to be a Vector based racer with Fox float shocks, the Mono-shock and billet rails. I cannot read Japanese, but it seems to be a very light model. It looks like it has a lightweight hood as well as raised seat, along with a bar riser...I do not yet know how to attach the picture...
I just noticed that it also has the same type of running board design as the titanium chassis shown on that Titanium RX-1; a tubular running board design!
srx70024
Pond Inlet, Nunavut ?
RX-Eskimo -
I looked that up on MapPoint. Wow!! you are way up north, huh? I'd like to see some pics from riding up there.
Must be beautiful !!
RX-Eskimo -
