I have done a few turbos on other sleds but not a SRX.
This would be my best guess for setup.
Install Power Jets on all carbs with #100 jet to start.
Use stock jetting for the rest for now. Recheck plugs and wash after it's running well. You will also need to drill and tap the tops of the carbs. Install hose barbs. also intall hose barbs in your new airbox. Run a hose from tops of carbs and ALL float bowl vents to the airbox. (your making pressure equal in the float bowls, top carb slide and intake) Now the carbs will work correctly when under pressure and normal vac.
For fuel, I install the Cat EFI pump. You will also need to install Regulator:
Fuel pressure regulator
You need a return line to run back to the tank.
Adjust fuel pressure to 10 MORE then boost.
THIS IS A MUST!
So 10lbs of boost is 20psi fuel pressure.
8 lbs = 18 psi, 6 lbs = 16 psi...
To turn on the fuel pump you need a NORMALY OPEN 5psi Hobbs switch:
Hobbs switch
Intstall the hobbs switch in the new airbox. It feels more then 5psi in the air box and turns on the pump.
