I just got back for a trip out west with my SRX700 powered mtn. sled and I was having some peculiar issues with it. The engine was just freshened and had Mega power heads installed along with some custom Hauck pipes. Other than that the engine is stock. I am running a stock airbox with the ATACC and jetted at 157.5 straight across with 45 pilots and screw out 1.5 turns and needles on third clip with both washers underneath the clip. I did two throttle chops with it, once in the midrange and once wide open. Both yeilded, gourgeous plug readings. Now the issue is when I am on the trails or on hardpack the engine pulls like a banshee. Once the engine gets into a climb with heavy snow or a lot of load and I go to grab a handfull of throttle, one of the cylinders will start dropping off and eventually will quit all together if I don't back out of it, when i do back out of it, all of the cylinders eventially light back up again as long as I don't go for wide open. This occurs on all cylinders randomly. When a cylinder does go down, I change out the plug and away I go. The mag checked out good and the coils checked out good at the Yamaha dealer. Is there a chance that I am jetted too fat in the main but my needle setting is lean enough that I can't see an issue until I go WFO? I am kinda confused.
If it is indeed a jetting issue, should I raise my needle and go smaller on the main a couple of sizes? Any help would be appreciated!
