2002srx7OO
Hey guys. I purchased a 2002 SRX 700 that has the following:
- Stage II Simons CPR 780 Big Bore Kit
- Camoplast Cobra 1.38" Lug Track
- Koso Temp Gauge
- Yamaha Billet Wheels
- 152.5 Jetting
The sled, other than what was noted above, is all stock (gearing, clutching, pipes/exhaust, reeds, etc.). Based on that, what would you mod to get the best performance? Oh, and I don't plan on studding the track, knowing that helps getting out of the hole from a standstill.
- Koso Temp Gauge
- 152.5 Jetting
shaggyzr2
Adjustable transfer rods will help you hook up better.
Big bore pipes.
staggs65
It needs clutching
YAMMIEGOD3:16
i am doing one right now. clutching. huge gains. 3:16x (yammie tony)
2002srx7OO
I had somewhat of an update, the guy said the only thing on the sled that is stock is the reeds and gearing. He isn't sure of how the clutching is setup, but they're shimmed, thundershift weights and isn't sure of the springs. He said to contact the original owner for the other details/specs.
staggs65
If they're the heavy hitters they'll work great. I ran 53 gram heavy hitters loaded with the 7/16 steel bolts in both holes. 150/300 primary spring. 50/40 helix with green at 70 in my 780. Good setup
2002srx7OO
He told me that where it has a 780 Big Bore, you keep the gearing stock. Is this true?
2002srx7OO
I'm looking at getting Boyesen Rage Cage's for the SRX, is the Mountain Max and SXR 700 Boyesen's the same?
chris700readhead
No the sx ones are smaller.
staggs65
Gearing depends on what you want. You can pull a taller gear with the 780 and still have good acceleration with clutching. I ran 24 38 in mine for trail and 1000ft radar runs. Grass and 660 I'd gear accordingly
YAMMIEGOD3:16
jeff, what base gaskets you use. 3:16x (yammie tony)
staggs65
Tony, just the stock srx base gasket.
YAMMIEGOD3:16
ok. thanks. 3:16x. (yammie tony)
2002srx7OO
Was told not to get V-Force 3 reeds, as they tend to wear and tear easily, checking to see what you guys think/know.
Mac
Yamaha reeds are of best quality. No gains with after market.
staggs65
V force 2 are good. Stock reeds are pretty good though. Very little to gain there until you start really upping the power
YAMMIEGOD3:16
stk reeds 3:16x
jabber800
I have to second the big bore pipes!! Once you add these it wakes up this engine like crazy.. If you decide to do the pipes it will change your complete set up so you will need clutching and gearing again... Id do the pipes first!!!
nick5oh
Adjustable transfer rods???? Where do these go? These are for a stock skid only right?
