2002srx7OO
Big Bore Pipes
I have to second the big bore pipes!! Once you add these it wakes up this engine like crazy.. If you decide to do the pipes it will change your complete set up so you will need clutching and gearing again... Id do the pipes first!!!
As in a silencer?
As in a silencer?
staggs65
No he's talking the bender big bore pipes. Replaces the complete exhaust.
YAMMIEGOD3:16
actually the bender big bore pipes run at stk peak. and make huge huge torque. these flat out work. 3:16x (yammie tony)
2002srx7OO
Good to know, are they hard to find?
2002srx7OO
I don't know what the previous owner updated me with, it might mean a lot...or not...but he said it has an "improved cdi box". Can someone fill me in about this, I'm semi-tech savy when it comes to sleds, but not "improved cdi box".
shaggyzr2
That could be the box from Hauck, it's just a viper CDI
2002srx7OO
Are the big bore pipes hard to find?
hman
They are kind of hard to find used but for $1300 you can still get them new from Bender. I picked up a used set awhile back reasonable but I plan to use them on a 780 I picked up a couple weeks ago.
2002srx7OO
What about those Power Inc. pipes with matching can? Or would it be better to get the big bore exhaust?
hman
They are slightly better than stock from what I have read but will also to be rather hard to find.
2ooosrx
- Oct 2, 2004
- Gurnee, Illinois
- www.cbperformanceparts.com
Power Incs are great on a stock engine but when you start uping the displacement, the big bores will have much more volume and better performance. The power Incs would be a slight improvement over stock though.
2002srx7OO
Good to know, seeing how I don't want to spend an 'arm and a leg' for a new big bore exhaust setup, I'll scour around for those Power Inc's.
staggs65
To see any noticeable gains over the stock pipes you need a big bore specific pipe. Bender is the most common. There are other companies that can build a set.
hman
One other thing to consider with the Big Bore pipes is that there not going to exit the stock hole so you will probably have to cut some extra holes in your right side panel. Nothing big but I have an 02 SRX that I bought new and had a 780 BB on it that I used for trail use and didn't want the extra noise or to have to cut holes in the side panel. I still have the 2002,2000 and a 1998 so I will cut the holes on the 98 as it has extra holes already.
2002srx7OO
I just messaged a guy here in Canada who is selling a Power Inc. pipes w/ can, depending on how much he's selling it all for, I am interested!
hman
That would be a good way to go. Here was a old post of my 02, the sled is a few years older than these pics but has only had a few hundred miles put on it since the pics. Bought some other sleds and this one has been in storage since.
http://www.totallyamaha.net/forums/showthread.php?t=33548
2002srx7OO
Where'd you get your temp gauge?
hman
I think it was a Cyberdine from Summit Racing. A must have for under $100. I would run in snow at around 145 and run up to around 180 in low snow. It has a blink alarm that you can set for high temp. And you can recall highest temp. But it resets after you turn the sled off.
You could get a monoschock rear suspension for that.
2002srx7OO
Now I'm thinking about getting studs for the track (Cobra 1.38"). Now my question is, what size/length stud should I use, without it damaging the heat exchanger (rad)?
